Feature Request/Bug: Move Material in Pause Menu
wdwms
Posted · Feature Request/Bug: Move Material in Pause Menu
Bug: If you pause a print and change the filament, after the filament starts to come out you verify it w/the control panel, and then it retracts again. So when you unpause your print it will print about 1-2 layers with nothing coming out (depending on the size of your print of course).
Feature Request: The pause menu needs the move material option added so that you can queue up the filament to resume the print.
Thanks!
-t
