Extruder Nozzle Scraping Previous layer..Is this normal??
Posted
(edited)
· Extruder Nozzle Scraping Previous layer..Is this normal??
It's normal to have some scraping if the layer height is low. It's usually a good thing, actually. The second time the nozzle goes over the material, it smoothes out the layer a bit more, just by pushing hot filament on top of it.
From what I can see in your picture, it is probably scraping too much though. Too much scraping is bad though since it will result in an uneven outer surface (as well as the inside). If you see that the wire is flattened such that it becomes wider, you should probably adjust the bed a bit lower. During the bed levelling, make sure that you can put a normal 80g-weight paper between the bed and the nozzle, and that you can feel just a little friction with the nozzle when moving the paper underneath.
ghostkeeper 105
Edited by GuestLink to post
