Printer 25% and as it moves, and draws the bosh elsewhere
ul22
Posted · Printer 25% and as it moves, and draws the bosh elsewhere
1. Check if the pulleys sit tightly on the rods
2. Make sure the belt tension is reasonable so neither the x nor the y motor does skip steps.
    I've checked after
    and they are not loose
    it virked not
    what should I do
