Printing marks? You mean the lines from the head moving? If so use Retract while combing pluging or move to $implify3d...
Also if you mean the marks from the head moving, you might need to check if you have combing 'all' so cura hides as best as he can the marks or use z-hop that will remove that but might add another kind of mark from the head moving up. You must choose what's the best/worse you can use.
ghostkeeper 105
It's hard to troubleshoot this. When I load up a print of a bottle, the G-code looks fine. I also looked up a model of a bicycle, like you said, and it requires a lot of support but otherwise it looks fine.
What settings are you using for your print?
