The software is behaving strangely
itzik
Posted · The software is behaving strangely
I'm useing cura 15.
I encountered a strange phenomenon when I print.
I print bottle and it's no't smooth , it has a lot of printing marks.
When I check the Gcode file I see that the program gives instructions I do not understand the reason for them.
Let's take an example of that cycle, the software creates a circle(1st layer) and on the circle creates a number of points and circle again.
I don't know why it doing the points and not just do another circle.
Thanks
    It's hard to troubleshoot this. When I load up a print of a bottle, the G-code looks fine. I also looked up a model of a bicycle, like you said, and it requires a lot of support but otherwise it looks fine.
    What settings are you using for your print?
    Posted (edited) · The software is behaving strangely
    Printing marks? You mean the lines from the head moving? If so use Retract while combing pluging or move to $implify3d...
    Also if you mean the marks from the head moving, you might need to check if you have combing 'all' so cura hides as best as he can the marks or use z-hop that will remove that but might add another kind of mark from the head moving up. You must choose what's the best/worse you can use.
