Posted (edited) · Sloping sides
Any ideas as to what could have caused this?
The box is standing on its end, base towards you and the square holes were at the rear of the printer. Both sides were the same, sloping inwards towards the rear of the print. The front is reasonably OK but with a slight overhang at the top.
PLA, 0.1mm layer, 210C, printed quite slow. An 11 hour print.
It's certainly not in the original model or is it seen in Cura. The top of the object, ( the part that sticks out ) is the correct size, the sides are sloping inwards.
Not seen the effect before and the current print looks fine.
