Nozzle heats up manually but doesn't when I hit "Print"
evan1034
Posted · Nozzle heats up manually but doesn't when I hit "Print"
I have the Ultimaker 2 extended and have done 3 prints. All worked fine, however, I tried to start a new print and the extruder did not heat up. When hitting the "remove material" button, the extruder heats up and the material comes out. Please help!
Things I've tried:
factory reset
different print
removing material and then putting it back in
