Could you run it as an admin and post the log file?
Yes, of course.
I'll do it next monday. I'm not at work now.
Thanks.
Yes, of course.
Thanks.
I'm sorry for the delay.
Here you are a copy of the cura.log :
Traceback (most recent call last):
File "c:\dev\uranium\UM\Qt\QtApplication.py", line 147, in event
File "c:\dev\uranium\UM\Event.py", line 149, in call
File "c:\dev\uranium\UM\Signal.py", line 96, in emit
File "c:\dev\uranium\UM\Backend\Backend.py", line 128, in _onSocketError
AttributeError: 'UnknownProtocolError' object has no attribute 'errno'
File "c:\dev\uranium\UM\Qt\Bindings\MainWindow.py", line 83, in mouseMoveEvent
File "c:\dev\uranium\UM\Qt\QtMouseDevice.py", line 30, in handleEvent
File "c:\dev\uranium\UM\Controller.py", line 211, in event
File "C:\Program Files (x86)\Cura_15.06.01\plugins\Tools\RotateTool\RotateTool.py", line 84, in event
angle = math.acos(drag_start.dot(drag_end))
ValueError: math domain error
File "c:\dev\uranium\UM\Qt\Bindings\ActiveToolProxy.py", line 59, in setProperty
AttributeError: 'RotateTool' object has no attribute 'setScaleX'
The only one thing I can tell you is that I don not have any folder called DEV in C drive.
Thanks
nallath 1,067
