Wall thickness doesn't apply to some layer
gloine
Posted · Wall thickness doesn't apply to some layer
Hello,
I am trying to slice an STL file with Cura 12.08. The problem I have is that my wall thickness setting doesn't apply to some (important) layer. Here is the model I want to print:
The STL file is here: https://www.dropbox.com/s/nxctctzmx05k61j/turbin.stl
I changed the wall thickness setting to 12 mm to make a concentric top cover, to save me from dangling infill lines.
(This is the only option I've changed from the default. I need to handle retractions later to successfully print it though.)
Unfortunately, I have the following unexpected 111th layer.
The 112th layer is fine as follows:
The height of bottom layer is 1mm, the blades 21mm, and the top cover 1mm.
Any idea why this happens?
Thank you.
Regards,
Gloine
    I just digged into the skeinforge code and found that the following three lines in fill.py caused the problem (line 884-886):
    		if rotatedLayer.rotation != None:		extraShells = 0		self.distanceFeedRate.addLine('( %s )' % layerRotation)
    It seems that if there is a layer which needs some bridging, skeinforge tries to move straight only. It makes sense in general but not for my case...
    So I commented them out and now everything is fine.
