I did use Cura. You're right, it does repeat at the same place but it is not across the entire circumference of the sphere at that layer. Almost as if where it is being split down the middle for slicing is the problem, maybe an odd number radius works better than even?
Two concentric spheres, as this simple cup is, should not have a heaver bottom that I know of so is cura just making some assumptions? I think the vase setting on the simple interface is just a collection of presets, anybody know what the collection is?
robmiles 1
Hi. I've seen this before in my prints. I think it is because at the bottom of the sides of the bowl, where the sides are thickest, the printer "fills in" each side with a wavy layer, which "sticks out" and gives the bumpy effect. You might be able to fix it by telling Cura (if you are using Cura) that you are making a vase. This should result in the sides being made of one layer thickness and get rid of the waves.
If has always intrigued me that defects like this are extremely repeatable. I've printed out a few of the vases from ThingUniverse (particularly the Roundem vase:
http://www.thingiverse.com/thing:20068
) and the lumps and bumps are always in exactly the same places.
