francfalco 39
Interesting.
So what is the procedure to change filament with a 'cold pull'?
I just follow the 'change material' sequence on the front panel and as you say, the filament is rewound hot from the nozzle often leaving behind fine strands.
Dim3nsioneer 559
This fine strains occur when you take out the filament HOT. That's why I always take it out with a cold pull.
To clean the Bowden tube I can recommend to use a piece of pipe cleaning wire which can be pushed through the tube by a piece of filament.
