Hot end fan
zungara
I build my Ultimaker, but i am not shure weather all is working fine.
I have made my first prints and they look optimziable but akzeptible.
But i wondering about the extruder fun. The fun is not working. I checked the connections but i found no misstake.
    are you sure you plugged in the cables into the right plug on the top of the hot end.
    i think the correct one for me was, purple... yellow.
    also dont be too worried if the little fan doesnt work, the little thing does not normally have a long life and reliability is a little.... iffy ?
    after 2 weeks of printing and testing, 1 blade from my original fan shot off the fan and then... dead...
    Ian
    To my understanding, the G-Code file makes the fan start and stop. Can you manually power it up with the ulticontroler?
    Yes, you can - and even dial in the speed from 0 to 255 (although mine won't start until around "60").
