Posted · Cura 15.06.03 Error Saving to SD Card
Our small business just got a new UM2. Some folks are having issues saving files to an SD card from Cura. When this error occurs, we're running the following:
PC Windows 7 Professional 64 bit
Cura says the part is saved to the SD card and then the card is ejected. Upon ejection nothing happens. When Cura is subsequently closed an error titled "Errors in 'Cura.exe'" is displayed. The error says "See the logfile 'C:\Program Files (x86)\Cura_15.06.03\Cura.log' for details."
The log says the following:
Traceback (most recent call last):
File "c:\dev\uranium\UM\Qt\Bindings\VisibleMessagesModel.py", line 64, in actionTriggered
File "c:\dev\uranium\UM\Signal.py", line 96, in emit
File "c:\dev\cura\cura\CuraApplication.py", line 528, in _onMessageActionTriggered
File "C:\Program Files (x86)\Cura_15.06.03\plugins\LocalFileStorage\LocalFileStorageDevice.py", line 29, in ejectRemovableDrive
self._removable_drives.ejectDrive(name, self._drives[name])
File "C:\Program Files (x86)\Cura_15.06.03\plugins\LocalFileStorage\WindowsRemovableDrives.py", line 91, in ejectDrive
if not windll.kernel32.DeviceIoControl(handle, IOCTL_STORAGE_EJECT_MEDIA, None, None, None, None, None, None):
OSError: exception: access violation writing 0x00000000
Not sure where to go from here. Any help is appreciated.
Thanks in advance!
