strange problem with small piece
simmosam
Posted · strange problem with small piece
Hello,
since a month I'm printing and with good success. Since I still have problems with plugs (even with Hotend V2.0!) I wanted to print the Bertho extruder update. I can print nearly all the parts but the Yoke part gives me a headache! One leg of this part is ok, but the other (right leg) won't print well, it seems that there's too much material for this. I print with the standard Cura parameters with 0.1 layer height. the parameter for extrusion i needed to adjust (100mm extruded was only 95mm measured; param adjusted to 867.xxxxxx)
The problem als occur when I tried to print Z_axis_long_body from http://www.thingiverse.com/thing:19912 th four islands are totally crap, it looks to me that these are being made with too much material.
Any Idea what is wrong?
Greetings,
Sam
