Posted · Heated Chamber Error
Hi everyone,
Here is the issue.
I build an Heated Chamber / sound isolated box for my Ultimaker Original +.
After 5 hours of printing. My printed object became a mess.
The chamber becomes actually pretty warm and i do not know what to do about it because i am a noob.
Has someone any suggestions??
Should I close the heated bed or add extra van? Do i need to tweak the settings or is it because of my bad bed-leveling build platform. I want to keep the Ultimaker in the heated chamber.
Here are the settings that i use for printing.
    • 3 weeks later...
    Posted (edited) · Heated Chamber Error
    Im no pro so ill just chime in having the same model as you.
    I use a brim with PLA and is has always seemed to help with bed adhesion. If I remember correctly PLA is not a big fan of heat chambers and that might be something more for ABS. In either case it would be a good idea to make sure the chamber is regulated evenly. You may not need a fan just simply a vent so the heated air will not continue to stack on itself and make the camber hotter than you need.
    If I where you I would try another print then take some ambient temperature readings with thermometer.  Something that can reach over 100c would be a good idea. Then adjust your vent to get a good level temperature. Im guessing anything above 60c will not work well for PLA but maybe one of the Pro's can chime in on this.
