Oh sorry, I´m using an Ultimaker 2 (on of the very first ones). Teflon Insulator is also new and looks fine.
Settings are different. No I´m printing an alternative feeder with 230° and layer 0.1..speed at 50 and adjust down to 80%. Still skipping.
My other UM2 (newer one) runs very well with 0.15mm and only 215° with the same settings and filament (colorfabb black).
DidierKlein 729
If the feeder is skipping it means that the printer is having a hard time pushing the filament at the requested feed rate.
What are the printing parameters you are using? (layer height, speeds).
Have you checked the Teflon Insulator? How many hours of printing does your printer have? (and what is your printer? you can add this to your profile
