Having trouble moving objects in Cura on Mac OS X with laptop touchpad
NonSequor
Posted · Having trouble moving objects in Cura on Mac OS X with laptop touchpad
Almost any time I try to move an object on the build platform in Cura, the object jumps way up and right of the cursor. If I drag my finger across the trackpad all the way from the top right to the bottom left, I'm barely able to get the object back to the point where it started.
Is there anything triggering this behavior or is there a workaround?
    Posted (edited) · Having trouble moving objects in Cura on Mac OS X with laptop touchpad
    @NonSequor: I would be interested to know if this still happens in the 15.10 open beta, which you can download from here:
    https://ultimaker.com/en/community/view/17296-cura-1510-open-beta
    This contains a fix for the objects jumping away if you touch them more than once (among many, many other fixes and new features, and in all likelihood some new bugs that will get fixed shortly).
