Posted
(edited)
· Cura setting first layer flow too high
I am using Cura version 15.04 on Linux (and some times MacOS). You set me on the right track though. I just built this printer and the Z0 position was too far down so to compensate I was setting my first layer height at 1mm when it should have been around .2 or .15. I knew from the G code that setting the first layer at 1mm would get Cura to shift the start position to Z1 but I didn't realize that it was also increasing the extrusion rate. I compared 2 G code files, one with the layer height at 1mm and one with the layer height at .15mm and the latter's extrusion rate is far more reasonable. Thanks for the help!
pm_dude 27
What version fo Cura are you using?
In the advanced tap can you make sure "Initial layer light width (%)" is set to 100.
Make sure you have no plugin that may affect the gcode in the plugin tab.
Also check that the Initial layer height make sense and is now mistakenly saying 1.5mm instead of 0.15mm for example.
adiab 0
Edited by GuestLink to post
