the X stepper belt seems to have loosened after the assembly. When the stepper changes rotation direction, I can clearly see the belt move a little sideways.
Small side movements are not really a sign for belt slack, but misaligned pinions, and are not detrimental to the printing process.
Unfortunately I cannot tension it anymore, as the stepper is already at the lowest position allowed by the mounting holes. Before extending these holes, any other point to check or suggestions?
If your belts make the spoing sound when plucked, you're good. Otherwise extent the stepper mounting holes, I did that as well.
alberto 0
A picture of the last printed object (80% default speed). Its roundness is still not satsfing me.
