If you read the instructions you will find an image on how you should apply the tape.
In lines, next to each other. Try to line them up precisely without any air or dirt underneath.
In theory you only need to cover the area where you are going to print, but unless it got damaged or dirty you don't need to remove the tape.
So taping the entire surface of the bed will allow you to print big and small, without the need of redoing the tape. When 1 strip got damaged, you only need to replace that one strip.
Your supply is enough for quite some time!
They may reflect on the bottom surface of your print, it is up to you to decide if that is a problem or not.
2090 is good, the shade of blue on your picture however looks like it is the 3434.
It works as well, but has less adhesion than 2090.
(3434 it is a great tape if you want to do autoprints for example).
SandervG 1,518
Hi Vissenkom,
What you are seeing is that your print got detached from the buildplate.
Usually you want the print to stay attached to the buildplate, and you'll have the printhead build the model. In order to create a form, it needs to build one layer on top of the next. This only works if that previous layer stays at the same place
In your case, it is moving along with the printhead. So nothing is being made, except a blob because the printhead does keep extruding.
I see you have an Ultimaker Original without a heated bed and you have some remains of the blue tape (it looks to be light blue?)
I would recommend to get out and buy some darker blue tape, put that on the buildplate and start another print. The tape should enhance the adhesion and you should be able to print reliably.
You can find some instructions here.
Good luck!
Edited by GuestLink to post
