Are you talking about the far right upstanding piece?
My first thought was that these pieces were not merged in CAD and therefor Cura identifies these as 2 parts. You could try to merge them, or use one of the 'fix horribles' in Cura (under expert mode).
Hope that helps (or I am interpreting your question right
Hi, thank you for your input.
Yes, the far right piece is the separate one. It shouldn't be a problem with the way I designed the model, as the two pieces overlap and I used
union()
piece 1
piece 2
to make the entire model.
Obviously I can just change the size of the holes in my model, and I don't actually have to use horizontal expansion to fix the sizing issues, but it was an interesting bug I thought I would share.
SandervG 1,522
