Yep, switching back to the original code resolves the problem. All the other variables are the same, so I can safely say that the problem lies in the gcode.
I haven't seen the brackets, so let me get back to you on that. The brackets are exactly at the moment I suspect the printer crashes/gets stuck. The G1 command to raise the nozzle works, but then nothing happens.
nallath 1,118
Are you sure it's caused by changing the start code? Does changing back again fix the issue?
I'm not quite sure how we handle the tags in the code, but I see you use multiple types of tags mixed with eachother (eg with {} and [])
