Daid,
Thanks for the quick reply and for Cura!.
Any suggestions to isolate the motor wiring as a root cause?
Daid,
Yes. Swapping just the motor cable from the X and Y connector (so X drivers moves the Y motor) and then test the motor, if the problem stays with the motor then the motor or motor wiring is the problem, else it's the driver, electronics or the Arduino.
Daid 301
If you swapped the motors cables around did the problem swap with the motor? If that's the case then you could have a cabling problem in your Y motor.
