Posted · Cura 15.04.2 temperature not showing
Assuming you have an Ultimaker 2 i doesn't need to show as it's set on the printer.
If you want it to show, i think you have to select rep rap (volumetric) in the gcode flavor. This is is set in the machine config (machine menu -> machine settings).
But as i said if you have an UM2 leave it in UltiGcode you won't need that setting.
    I'm pretty sure you need to use RepRap(marlin/sprinter) to use the Ultimaker2 this way, in this case you also need to set start & end codes, search this forum there's plenty of info around..
    To be honest I don't know what the "volumetric" does.... but RepRap(marlin/sprinter) works for sure.
          • Heart
        • 4 replies
