cura does not work with .stl file
Pindrejo
Posted · cura does not work with .stl file
Hi! I have a problem...
I created some pieces in 123d desing, and have exported the .stl file, but to open it in Cura, the piece comes in gray and not make the slice, so it does not print .. It has happened to me with many pieces, even I tried to repair using netfabb, but nothing ...
    I think the model is too big for the print bed (not in front of Cura at the moment). Click on the model and then select the scale icon at the bottom left of the print bed window. Reduce the size until the model is yellow.
