Temperature dropping
ceramicbullet
Posted (edited) · Temperature dropping
Hello all! I've been having some trouble getting my UM2e to print ABS. I've tried many things to get this to stick to the glass, but every time I print, Cura insists on dropping the nozzle temp to 207C despite the machine being set to 230C. As soon as I hit print, I have to wait for it to cool down. How can I stop this from happening?
[Edit: Forgot to mention, I'm printing via USB with RepRap(marlin) setting]
    Posted · Temperature dropping
    By setting temperature to 230°C? If you already have you should save the gcode to a file instead of starting the print and then check within the first lines what Cura writes in the M109 or M104 commands.
    Uhhm... I would rather call this a work-around than a solution except you figured out which setting made the difference... :O In that case, please let us know so others may profit from this thread.
