Hey SandervG,
thanks for the quick answer.
I connected the printer via USB and did it like in the heat bed installation manual:
I updated the firmware with cura ('add new printer'-window, where I could tell what changes I made), then first moved the extruder-head-thing to to all x,y,z endstops (clicked the bottom end stop manual, because it was required), then I did the bed calibration with paper and setting the spring.
The nozzle is not very far, only few milimeters, but to much to print properly.
I didn't change the end stop, during calibration.
SandervG 1,518
Hi @UltiSo,
When you say you calibrated the heated bed, what did you do exactly?
How far is it from the nozzle?
Did you change the position of the end stop (during calibration?)
The Ultimaker Original should determine its height based on the top end stop, not based on the bottom end stop.
