(Cura also has a GCode preview, so you could have seen it there)
Cura shows those little red lines after slicing, those are actual errors that the slicer sees in the model, could be holes or duplicate faces. Most likely one of those is causing the erroneous infill.
You could try running the model trough netfabb cloud, or slicing at a slightly different layer thickness (which could be why the original creator of the model never ran into this problem)
Daid 306
