Bronzefil is abrasive stuff.
Are you sure you assembled it correctly. As long as its staying on the bearing it should be fine. can you see if the filament is coming off?
there other feeders you can print like THIS one but you need to get it printing first.
Make sure the filament is on the knurled part of the drive wheel.
I am quite sure that I assembeld it correctly for I didn't take the wheel with the carved housing apart. As far as I can tell the filament tends to bend into the carving (which is exactly as wide as the filament) and so the knurled part of the drive wheel has to work against the fricition created by the bend. I also noticed that there is no skipped back steps by the feeder motor which i heard often when the filament can't advance. The knurled wheel just bites into the filament until its completly grinded and there's no contact at all.
The carved in part is located at the backside of the feeder so I can't really see how exactly things get messed up. I wonder if I could print with PLA before because it is stiffer than Bronzefill and doesn't bend into the carving as much?
When theres little to no friction to the filament like when changing material, the feeder acts normal, but as soon as it is pushing through the nozzle the filament gets grinded.
Labern 773
