Circles are slightly oval, but I'm not sure belt tension can completely explain this.
This is a pic of what the nickel calibration test that I did was supposed to look like.
Instead of what is shown above, My print was a bit messier. The walls of the slots were separated from the infill by about 1mm on both sides of the walls on the X axis. The circle had a similar problem. However the Y axis connected all of it's walls just fine.
Daid 303
Sounds like a belt tension problem, are your circles round or oval/square?
