Buying a used Ultimaker 2
Posted · Buying a used Ultimaker 2
Hey everyone,
I'm planning on buying a second-hand Ultimaker 2 tomorrow. The seller owns a printshop and apparently knows his trade. The device has been printing for 1450 hours and no significant signs of usage. It also has an Olson Block installed for interchangeable nozzles.
I don't want to buy a pig in a poke, so I'd like to ask the experts (I'm an absolute beginner):
What should I watch out for? Where can I find some margin to negotiate?
The printer will be demonstrated tomorrow with a test print of 26 minutes.
Thanks in advance for your help!
    Posted (edited) · Buying a used Ultimaker 2
    - check without power if the print head can be easily moved by hand
    - check if the frame is without damage and still sturdy
    - check with callipers if the size of the printed object is correct, and print a long object, not a small cube.
    - don't let it print slow, use a fast setting, to see if there are any mechanical problems.
    - test if exchanging filament goes without problems.
    - check the temperature of the heated bed.
    - and see what guarantee duration he gives after purchase.
    • Like 4
        • 56 replies
        • 30 replies
