Ultiboard v2 problem with connection
jean-baptiste
Posted (edited) · Ultiboard v2 problem with connection
Hi everybody !
I have a big problem with my new UltimakerBoard v2.1.1
When I connect it to the usb (with powersupply), led power go to green but it's go to connect and disconnect in loop with unrecognized usb device.
I think maybe the problem come of ATMEL 16u2, but I haven't absolute no idea how can I burn it with the hex file:
https://github.com/Ultimaker/UltiboardV2-usbserial
I have the USBtinyISP but I do not use ATMEL Flip with it to burn...
Help please !
Thanks a lot !
Jean-Baptiste
    Posted · Ultiboard v2 problem with connection
    New answer !
    I was able to burn the 16u2 but the problem they same (connect & disconnect loop)...
    C:\WINDOWS\system32>avrdude -c usbtiny -p m16u2 -U flash:w:\Users\Jean-Baptiste\
    Downloads\UltiboardV2-usbserial-master\UltiboardV2-usbserial-master\UltiboardV2-
    usbserial.hex
    avrdude: AVR device initialized and ready to accept instructions
    Reading | ################################################## | 100% 0.01s
    avrdude: Device signature = 0x1e9489
    avrdude: NOTE: "flash" memory has been specified, an erase cycle will be perform
    ed
    To disable this feature, specify the -D option.
    avrdude: erasing chip
    avrdude: reading input file "\Users\Jean-Baptiste\Downloads\UltiboardV2-usbseria
    l-master\UltiboardV2-usbserial-master\UltiboardV2-usbserial.hex"
    avrdude: input file \Users\Jean-Baptiste\Downloads\UltiboardV2-usbserial-master\
    UltiboardV2-usbserial-master\UltiboardV2-usbserial.hex auto detected as Intel He
    x
    avrdude: writing flash (4078 bytes):
    Writing | ################################################## | 100% 10.42s
    avrdude: 4078 bytes of flash written
    avrdude: verifying flash memory against \Users\Jean-Baptiste\Downloads\Ultiboard
    V2-usbserial-master\UltiboardV2-usbserial-master\UltiboardV2-usbserial.hex:
    avrdude: load data flash data from input file \Users\Jean-Baptiste\Downloads\Ult
    iboardV2-usbserial-master\UltiboardV2-usbserial-master\UltiboardV2-usbserial.hex
    x
    UltiboardV2-usbserial-master\UltiboardV2-usbserial.hex contains 4078 bytes
    avrdude: reading on-chip flash data:
    Reading | ################################################## | 100% 5.75s
    avrdude: verifying ...
    avrdude: 4078 bytes of flash verified
    avrdude: safemode: Fuses OK (E:F4, H:D9, L:FF)
    avrdude done. Thank you.
