UM2 - from original gear to MK7 - which settings?
Posted · UM2 - from original gear to MK7 - which settings?
Hello,
i've modded my UM2 with a Reprap Bulldog feeder (link to my post in the german section), original UM2 stepper motor.
For that i've changed the original gear with a MK7 gear.
The MK7 gear ist bigger than the original:
original scope: 25,13mm
MK7 scope: 34,55mm
So with the bigger scope there is more material transportation. Which settings must be changed - flow, filament diameter, e stepping?
For now i've changed the material flow on the UM2 to 95%, which seems to be quite good.
Thanks
Marcus
        • 30 replies
