drawbench
Crcic
Yes, it's PLA, and temp is 230
Also the travel speed is 250..
Hi more details could be usefull!
I guess you are annoyed by the strings...
Is it PLA? if yes reduce the temp to 210°c 230°c is a lot!
Make sure retractions are enabled
Maybe increase travel speed to 250mm/s
    The retraction setting is length 5 and speed 40
    Is that a retraction issue?
    How to change the retraction setting to make it better?
    And how to avoid it without slow the print speed?
    yes if you want to avoid strings then reduce the print temp it will be better
    Maybe slow the print speed to 30 - 40mm/s
    As i said try with lower print temperature! For pla 210°c should work just fine
