Visible lines in first layer and bubble-like indentations?
Posted
· Visible lines in first layer and bubble-like indentations?
70C is quite high and higher then the glass transition temp of most PLA's
the default temp on UM2 is 60C and I also print at 50 all the time.
You can also get those bubble marks where it doesn't stick, you can see it peel up as it goes over those points when printing the first layer. maybe where you touched it or oil dripped on it. A good clean with Alcohol may help.
Posted
Thanks for the info, It's in the middle of a print at the moment but I lowered the temp down to 55 before it started to see how it went.
I'll give it a clean after the print finishes, thanks.
Labern 775
Dalemaunder 1
