I didn't understand your entire message, or more precisely your train of thought (why is 14.09 not right for Ultimaker 2 Extended?)
Good luck!
Because
heater error
14.09 - does not have the feature
14.12 oct 16, 2014 - feature introduced 20C in 20 Seconds
14.12.1 dec 15, 2014 - from 20C to 10C (still in 20 seconds)
15.01 jan 14, 2015 - from 20 secs to 30 secs (now 10C in 30 seconds)
Anyway, if you have an Olsson Block and it triggers temp errors i could be that either you broke your PT100 or cartridge heater, or your heaterblock is touching your fanshroud.
My customer bought a new PT100b and heater cartridge. I did the installation. and dont touching fan bracket.
Today I make another checks and tests.
SandervG 1,522
This can function as a heatsink and guide the heath away.
When your heaterblock takes to long to reach its temperature it can trigger a temp error.
Remove the fanshroud and see if there is anything black, try to calibrate it so it doesn't touch it, or if necessary bend the fan shroud a little bit.
Good luck!
