My UM2 displays the following error message Z screw stuck
ferdinand981
Posted (edited) · My UM2 displays the following error message Z screw stuck
However the bill played moves freely by hand but the Um2 is not able to lower the built played even when requested through the advanced menu when I pressed the lower button it just brings the bill plate further up
    Posted · My UM2 displays the following error message Z screw stuck
    Can you move it by turning the screw by hand (with printer shut down)?
    If yes lift it up by hand and check if the z switch can be actived (you can find it inside the printer underneath the build plate (when it sits at the bottom). At the backside, there is a hole.
    The build plate has a screw underneath that goes in that hole to activate the z switch.
    You can try to click it with a screw driver
    Maybe some plastic is stuck in there
        • 26 replies
