Add servo motherboard and update Marlin / Double extrusion
greglamouche
Posted · Add servo motherboard and update Marlin / Double extrusion
Hello everybody,
i would like to add a servo to my UM2 for double extruder but i don't know where can i plug it on my motherboard in order to manage it.
I tried to change the marlin sofware to use one extruder for two head and one servo to tilt from the first head to the second head (http://www.thingiverse.com/thing:673816/#files)
I changed this file like that :
Configuration.h:
#define MOTHERBOARD 72
// This defines the number of extruders
#ifndef EXTRUDERS
#define EXTRUDERS 2
#define DONDOLO_SERVOPOS_E0 110
#define DONDOLO_SERVOPOS_E1 10
#define DONDOLO_SERVO_DELAY 1000
#define TEMP_SENSOR_1 1 // 0
#define INVERT_E1_DIR true // false
#define NUM_SERVOS 1
Marlin_Main.cpp:
else if(code_seen('T'))
tmp_extruder = code_value();
//Added for DEISS dual extruder
if(tmp_extruder == 0) {
st_synchronize();
servos[0].attach(SERVO0_PIN);
servos[0].write(servopos_extruder_0);
delay (servopos_delay);
servos[0].detach();
if(tmp_extruder == 1) {
st_synchronize();
servos[0].write(servopos_extruder_1);
delay(servopos_delay);
servos[0].detach();
//end
if(tmp_extruder >= EXTRUDERS) {
pins.h:
MOTHERBOARD == 72
#define E0_STEP_PIN 42
#define E0_DIR_PIN 43
#define E0_ENABLE_PIN 37
// the extruder 1 pins as the extruder 0.
#define E1_STEP_PIN 42
#define E1_DIR_PIN 43
#define E1_ENABLE_PIN 37
//i must define the "SERVO0" pin
#ifdef NUM_SERVOS
#define SERVO0_PIN 11 // i used 11 but i don't know which pin i can use and where i can plug on my board
#endif
#endif
// end
PLease, could you help me?
Thank in advance!!!
Greg.
