tinkergnome 929
This usually happens when the head looses temperature, it's triggered if the temp goes down from 10°c (or something like that). Does it happen when the fan is at 100%?
Didier, don't mix it with the "Heater error" - that's a different thing...
A "Temp sensor" error is triggered if the sensor reading yields to less than 5°C or more than 275°C.
What's the printing temperature?
DidierKlein 730
Odd for a new printer... Can you check if the temp sensor is well inserted? (It's one of the two white cables that go to the head).
Can you show a pic of the head?
