Posted · Cura keeps resetting itself!
Hi all,
I did a quick search but didn't find anything on the topic, apologies in advance of its already been discussed.
So I've had my Printrbot Simple Metal and im having an odd thing happen to me. Cura 15.04.03 keeps resetting itself every time I need to relaunch it, which right now, is every time after a print is finished because Cura will hang once the jobs done and ill have to crash it to continue?! Every time I relaunch, Cura will ask me what printer I'm using and go through the whole initial setup routine which frankly is getting a bit annoying now :D it sometimes retains the settings from the last print, sometimes not, it's pretty inconsistent.
I'm currently using a Gigabyte Q2005 Netbook running Windows 7 to handle Cura which bar one or 2 issues has been fine. Anybody have an idea why Cura keeps resetting itself? I use Cura at work and I've never experienced this issue.
