Yes .. it's like I pressed the tube too much into the white part. :(
Edited by Guest- 8 months later...
Would you mind sharing the solution so others who have the same problem know how to fix too?
Edited by GuestI found a solution, not the best but I'm good now
Nicolinux 288
Just to make sure, I guess you did press down the white part and wiggled the bowden left and right?
