True - I've needed to adjust those, but the grinding sound was happening only during the initial motion towards the center of the bed after homing.
(but its now gone away as mysteriously as it came)
I've also been experiencing this. After the Ultimaker heats up and releases the initial puddle of material at (0,0), it moves to the center of the table to begin the part and grinds really loudly as it does so. The noise also goes away once the part starts to print.
We think it might be related to the fact that we're at the end of the spool of material and the bend in it might cause it to pull, as we just ran a new spool and didn't get the grinding sound, but we aren't sure.
Anyone else have ideas on what the issue might be?
joergen 2
it sounds like your end-switches are not triggered, because they are too far away from the sliding block. I would suggest to move the head by hand to the corner where this occurs, and listen if the switches are reliably triggered or not. if not, loosen the screws, and move them further inward until they can be triggered.
