what du you mean? Which printer do you use?
well an umo+
I ment I was curious to try controll the feeding to get some oozing before print.
But I did push it too much ended up blocking the nozzle etc.. Had to take everything apart and cut off a short bit from the tube also cos the filament jammed up like a spotweld,
Nicolinux 288
