Setting Cura to print object with extruder 1 and support with extruder 2
markfarnell
Posted · Setting Cura to print object with extruder 1 and support with extruder 2
I am running Cura 15.04.4 for OS X, and I have a Prusa Mendel i3 with dual extruder. How can I set Cura to print objects with extruder 1, and support structures with extruder 2?
The only reason I bought the dual extruder printer is to enable me to print water-soluble support structures.
Thanks!
    There is a setting called "Support dual extrusion". Set it to "second extruder"
    Thanks! So in File->Machine Settings->Extruder Count, I can set the number of extruders. Then in "support dual extruder, I can set it to "second extruder". But how can I ensure the object (in the STL file) itself is only printed by the extruder 1?
    Also, where can I specify the position of the second extruder relative to the first extruder? Is this in the firmware itself?
    Thanks!
    Mark
    Thx! So once I sorted out the problems when printing with only extruder 1 (see my post in the cura section where cura prints the first layer at 20mm above the heated bed), then I will experiment on dual extrusion :)
        • 24 replies
