Posted · looking for cura setting
Most likely you are not extruding enough material. This could be mechanical (filament slipping in your drive), your filament diameter setting could be wrong, or you could adjust the steps-per-e in the preferences to a higher value.
    I recognize these problems, and guess that your belt tension is not yet correct.
    Check this
    by ultimaker
    You should soon see that the harmonic vibration of your belts isn't high pitched enough
    !!edit!!
    Mind that the correct belt tension should resemble about 7mm when u push it in the middle.
