Thanks, Daid! That's good to know. I screwed my plexiglass down nearly all the way so my printer is around 206-207 mm now too. Given your accounting for 5 mm in the bed design change, the shortage becomes a mysteriously-missing 8mm. I'm not very motivated to find the missing millimeters because, like most users, my Z-travel is adequate for my needs. I mostly wanted people to be aware of the true Z-travel capability of a currently shipping kit.
I think someone just made a mistake, because even on the oldest kits have the same amount of Z travel. (I have one of the first 20 machines here in our FabLab, which hardly looks like an Ultimaker)
FYI, the 22cm came from the first design which didn't have the spring loaded bed. And a different weaker Z stage design. The text in the shop is changed now, so no more false advertizement, thanks for pointing out the mistake!
No problem and the new spec in the shop looks good, Daid! I'd rather have the current bed than the extra 1-1/2 cm! In fact, I like the spring loaded bed so much, I just milled the same style slots in two 2.5 mm glass plates for my new heated build plate. Milling glass is painstakingly slow!
I'm pleased Ultimaker was responsive and changed it promptly. I was a sort of a "specmeister" in my last job and it's my nature to verify specs, I guess!
Daid 301
The bed was changed from 6mm to 11mm, so that's where 5 extra mm went. Not sure where the last 10mm has to come from. The machine I have here measures about 207mm from min to max Z.
