Cura stopped slicing
Mjolinor
Posted · Cura stopped slicing
I have been using Cura with my Wanhao Duplicator 3 since 14.03. I tend not to bother updating too often as it all seems to work extremely well for me but I will try new version as and when the desire hits me.
At some unknown time in the last few weeks I cannot get it to slice if I have the "Machine centre 0,0" ticked in machine settings. If I untick that then all works as it should but when I tick it then it will not slice.
If I run from teh command line I get a Python error so I am thinking that it is something else that I have installed or modified since I last used Cura. I have tried 14.02 - .04, they are all the same. I have to fix this or I am restricted to positioning things at the front left in Cura and having them print rear right on the machine.
Command line output:
Listening for engine communications on 49674
Exception in thread Thread-4:
Traceback (most recent call last):
 File "/usr/lib/python2.7/threading.py", line 810, in __bootstrap_inner
   self.run()
 File "/usr/lib/python2.7/threading.py", line 763, in run
   self.__target(*self.__args, **self.__kwargs)
 File "/usr/share/cura/Cura/util/sliceEngine.py", line 346, in _runEngine
   pos += (objMin + objMax) / 2.0 * 1000
TypeError: Cannot cast ufunc add output from dtype('float64') to dtype('int32') with casting rule 'same_kind'
    Well I have trawled the internet and reinstalled all the software including Python and all it's bits and numpy, edited all the files that stood even the most remote chance of fixing it and nothing doing, still the same. This is my last hope, if I can't get a fix here then sadly and with much regret Cura and I will have to part and go our separate ways. A sad day indeed.
        • 2 replies
