improving print quality, any help/experience?
xonegon
Posted · improving print quality, any help/experience?
I'm trying to improve the print quality one my ultimaker, you can see the tiny blobs on there.
  • too much filament = correct diameter?
    to hot currently 200°C ?
Also the top extrusion is very bad, it ruined the piece...
Using Cura 10.9 an mac.
Mendelworld PLA filament "3mm"
the back worked out great.
    While I'm no expert, I think there are a variety of things that can cause this. Things I would be looking at:
    • Size of filament setting matching the actual size
      packing density
      minimum layer time
      minimum feed rate
      Fan on or off
      speed of printing
      layer size. Looks like pretty big layers.
    -John
    It's definitely bad cheap filament, the red filament delivered with the ultimaker does not show these blobs.
    Measuring the filament it varied from 2,76mm till 2,92mm.
    So I guess this topic should really be in the cura section.. :roll:
