It's the heater, not the sensor. If the sensor was broken it would be reporting 0C or 1000C or most likely something like "temp sensor error".
It's your heater that is intermittent. Are you sure the wires under the machine are okay? Probably they are fine if you didn't muck with that.
You are in USA so probably the cheapest place to get good heaters is at my store and I recommend you get a 35W heater as you can print more volume if you ever go with an Olsson block. http://gr5.org/store/
gr5 2,243
