Advise for Ultimaker 2+ extended .8 nozzle printing needed
use a higher initial layer (about 0.5mm) and you might need to increase the nozzle temp some more. 0.8 nozzle requires a lot higher temp at the same speed that you would use for PLA.
Going with the 1/2 the nozzle size formula for the level size worked. I managed to go down to .3 and get a good print. Temps were not changed at all. (Matterhacker natural 5 lb spool prints best at 200.) Maybe the 2+ has better temperature control to compensate the larger available nozzles?
I had zero infill and no supports at all, and other than a few places that were horizontal and dropped out some, the print came out great!
Labern 775
Edited by GuestLink to post
gareee 39
